Customers can receive coupons (Coupons) directly on the platform and enjoy the price concessions. The amount of each coupon is 18 Canadian dollars and the number of coupons is 100.
Activity time: 2018-11-11 to 2018-11-30
Now Buy (Amazon CA)
https://www.amazon.ca/dp/B07F2ZTKPH
Beelink Gemini x
*【More powerful processor】Beelink Gmini X45 mini pc adopt latest ultra-low-power Atom Gemini lake J4105 processor(4M Cache,4 Core 4 threads 1.5 up to 2.5GHZ) and Intel HD Graphics 600, CPU execution speed faster 80% than N3450, N4200, J3455, X5-Z8350.Beelink Gmini X45 IEEE 802.11a / b / g / n / ac 2.4G + 5.8G and 1000Mbps LAN, enjoy what you love easily, get rid of buffering, stuttering or freezing
*【Memory and storage upgrade】Beelink Gmini X45 Mini pc DDR4 4GB RAM +64GB 3D EMMC+ 2.5-inch HDD (up to 2TB)+M.2 2242 SSD (up to 320GB) Extended capacity (2.5 HD / SSD card not included ). download your favorite programs and movies as you like, with smooth and responsive surfing and fast-paced apps.
*【Dual HDMI 4K Output】Beelink Gmini X45 equipped with latest Dual HDMI type ports and Ultra HD Graphics 600 provide 4K Output image resolution.Supports simultaneous display of different task modes.And Four high level USB 3.0 interfaces can many-sided meet the needs of customers.
*【Dual Wifi+Bluetooth】Dual WiFi 2.4+5.8 and BT 4.0 antenna design,more faster and stable.The WIFI antenna is mounted directly on the luminaire and then the acrylic panel is installed.This WiFi design can completely avoids metal having a shielding effect on WIFI signals.
*【New Cooling Method】Good heat disspation design to ensure hign performance operation in hign temperature,when cpu usage is 100%,fan runs 3800rpm,this makes a good heat dissipation and low-noise.The middle frame and the bottom shell are made of metal aluminum, which can increase the heat disspation.
Youtube: http://t.cn/RDp97bi
Beelink Facebook:https://www.facebook.com/Beelink.fans/
Beelink Twitter:https://twitter.com/Beelinkofficial
Beelink Google+:https://plus.google.com/+BeelinkOfficial
Beelink instagram:https://www.instagram.com/beelink_official/
Beelink Official:www.bee-link.com
service email: beelinkservice@bee-link.com
