Android Smart TV RK3188 Bricked - Need Help For Suitable Firmware
Originally posted by memandawazer View Post
if you have a Stockrom you can use "resource.img" & kernel.img to get Wifi & Ethernet working ,
on a good runnig Rom , most times , good luck / gefattern
Originally posted by neomode View PostSomehow I remember this Device.
Was called Q7.
Let me see if I have the Firmware somewhere.
Neomode
Editing kernel its to hard for me
Geekbuying has several rk3188 firmware on their blog. They have this post on how to ID some of the RK3188 boxes like the Q7 and others. Some firmware are linked there, I don't know if the links are active.
My 3188 box has the RTL8188E and MT6622N Bluetooth chip, so doubt anything I have would be helpful to you firmware wise.
Good luck.
NOTE: I do not know if any firmware linked from their blog is suitable for your 3188 box.
Originally posted by RISCy Dude View PostGeekbuying has several rk3188 firmware on their blog. They have this post on how to ID some of the RK3188 boxes like the Q7 and others. Some firmware are linked there, I don't know if the links are active.
Good luck.
Using the Q7 firmware that support RTL8188EU, running smooth...but internet is not functioning...via wifi or lan...both failed to turn on and connecting...
Stil trying to find the right firmware..
thanks anyway...
Without more information, finding a perfect matched firmware will be a challenge.
A thread was started ages ago to help ID the many variants of the look-a-like 3188 boxes. Maybe a look through there will lead to a solution. Most links to Freaktab posts in that thread will be incorrect. You will need to change the link. An example...
http://www.freaktab.com/showthread.php?12566-Q7-Firmware-by-lewy20041 -Won't work.
https://forum.freaktab.com/showthread.php?12566-Q7-Firmware-by-lewy20041-Should work.
You may also want to try searching the 3188 section for RTL8723AS, if you haven't already.
Hope you find something.
Originally posted by RISCy Dude View PostWithout more information, finding a perfect matched firmware will be a challenge.
But all link for the firmware is dead lol
There are currently 2299 users online. 0 members and 2299 guests.
