Linux multi boot on Minix Neo X8-h Plus
    Hello,
    Am a little confused how to make a multi boot on my Neo X8-h plus.
    I followed the next tutorial:
    Now all images Armbian and LE has all the files for activate the multi-boot. Anything in addition to download and copy to media is not required.
    1. Download the desired image
    2. Unpack
    3. Record an image on the medium
    4. to run Android
    5. open the app "Update&Backup"
    6. Select local update and an archive on removable media (aml_update.zip)
    7. Run update
    8. System twice to reboot and start running the system from external media.
    9. If after 7-10 minutes on the monitor not to receive any messages on system startup. Turn off TV box and add in manual in the first partition (FAT) the file "dtb.img". On the media there is a directory dtb from where you can take the files and copy them to the root of the renaming of "dtb.img".
    Need to pick up the option for the file system will run. Pay attention, after you add\change the dtb file, you need to try to run the system and waiting to run 7-10 minutes. If not happened, repeat with a different dtb file.
    Attention !!!! On models with S802 S805 S812. Activation multi-boot is possible ONLY with SD card (activation of the USB stick is NOT WORKING). After a one-time activation procedure is multi-boot, run a variety of systems is possible from ANY storage media (SD cards and USB storage devices).
    __________________________________________________ __________________________________________________ ______________________________
    When i look at the reply from balbes150 and go to the images i only see 812 is this the same?
    And the autoscript is
    S805_aml_autoscript says does this work on S802?
    The reasons i ask is that i don't want to brick my device.
    Armbian_5.64_Aml-s812
    balbes150 replied
    01-06-2017, 11:31
    Linux for Amlogic S802 \ S812
    http://freaktab.com/forum/tv-player-...ogic-s802-s812
    Thanks for the reponse!
    A little bit futher now but NON of the .dtb files are working so it's not booting
    meson8_k200b_1G_emmc_sdhc.dtb
    meson8_k200b_1G_emmc_sdio.dtb
    meson8_k200b_2G_emmc_sdhc.dtb
    meson8m2_n200_1G.dtb
    meson8m2_n200_2G_LAN100.dtb
    meson8m2_n200_2G_SD1.dtb
    meson8m2_n200C_1G.dtb
    meson8m2_n200C_2G_LAN100.dtb
    meson8_k200b_2G_emmc_sdio.dtb
    meson8m2_n200_2G.dtb
    meson8m2_n200_2G_M8SPlus.dtb
    meson8m2_n200_2G_MXIIIPlus.dtb
    meson8m2_n200C_2G.dtb
    Can someone help me with this because the screen is staying black and no boot.
