Playing game using g-sensor and gyro from RKRemoteControl
    I want to play Asphalt 7 using my Android phone as remote control for which I am using the RKRemoteControl app.
    I have got everything to work and after enabling the g-sensor and gyro in the app, the car turns left or right as I turn my phone.
    However the problem I am facing is the entire screen also moves along with it and this is very difficult on the eyes.
    I want to be able to turn only the car without the background turning along with it.
    Is there anything I can do for this?
    -Thanks
    Nikhil
    AW: Playing game using g-sensor and gyro from RKRemoteControl
    I think in asphalt7 its not possible, as it is coded to do this...
    _________________________
    tapatalked from GalaxyS3
      Thanks for your response FadeEx.
      I guess then I'll have to use my keyboard.
      Using the phone was easier for my son though.
        Try droidmote, its working
        from Nexus 7 with Tapatalk 4
        CS918(old wifi)+Air Mouse ea-01
        Out: TV LG HDMI (1 day a week AV out Samsung Tv)
        CX919(wifi ap6210)+Mele F10
        Out: TV LG HDMI
