MeCool M8S Pro L S912 3G 32G DDR3 Box Questions?
    Good evening! i have a few question i got this box a few years ago did a fan mod and installed the Nexus Firmware. i use the box for Kodi and other stream apk's, i have a few questions if i may:
    1) what is the preferred firmware to use for this box?
    2) when using kodi, if any one is what are the preferred settings for the video and audio on the kodi side of it?
    3) i am not sure of the proper audio settings on the kodi side, i am using a Sony Soundbar Model #SA-WCT100 it's a few years old but its great. the one audio issue i have is it seems like the sounds are much louder than the voices. not sure if it's an audio setting or how to configure it to be correct.
    3) on some movies/tv shows that are being streamed using kodi add'-ons i see some green Pixelization on the screen, again i assume this is a setting that i haven't done correctly.
    So the main thing is am i using the correct firmware, and what is the proper way to configure the kodi side for it to run the best?
    Thanks hope all these questions are ok
    i am waiting too
