ONLY 1GB RAM?? Alfawise H96 Pro+ (CZ-S32-V2.2)
    Okay guys I'm very confused right now.
    Only ROM that I can flash that's actually booting is aml_7.1_s912_q9377-H96PROPLUS_912_mac-20170602. I can't get any other to boot even if the flash succeeds(using USB Burning Tool). Using SD card method to flash, fails every time on "Upgrading" screen.
    Nothing would be a problem, if my box wasn't working veery slowly. I went ahead and installed AIDA64 to see if there's anything wrong, and I didn't believe what I saw:
    I have ONLY 1GB of RAM???
    ROM which came preinstalled with the box, was showing 3GB, and box was working much smoother, although it was overheating and was bloated, so I wanted to try how custom ROM would work, so... where exactly did 2gb got lost through the way, and why I cannot flash any ROM which would have to work? I have spent more than 10 hours trying to get this baby working, but few more and I will throw it in the trash bin.
    Whom did you buy it from?
    Contact them and ask for a link to the original firmware...to reset the box..OTA update is reporting incorrect or faulty info.
      Bought from Banggood.
      I will ask them and hope for the best. Thanks
