Version with Android TV + voice remote control.
Soft factory not modified.
After sleeping the box and waking up, everything works, including Wi-Fi.
The problem is that after waking up does not work bluetooth. Like everything in the settings is Ok, he is awake, paired, etc.
However, no device is connected. The solution for getting the connection is to disable and re-enable the bluetooth or reboot box.
Another problem is pairing bluetooth devices. Pairing occurs only after one time with most devices. The device must be 20-30 cm away. Otherwise, the device will not pair. After pairing, everything is stable.
Any ideas for fixing the problem?
One more question.
My version is LS. What room can I upload to it?
Will I lose my ability to watch Netflix in Full HD after uploading?
Will I be able to return to the stock?
In this version, do I have to check what memory do I have before uploading the room?
Thank you in advance for your help
