[ROM] Beelink GS1 SCV1 - Custom Rom ( Normal Android 7 )
    Hi there guys and girls, one more rom/fw for you all!
    This one took me a bit since theirs no tools for it or their are to old... i had to be a bit inventive
    Not really a bad box, i thought it will be worse but it did surprised me!
    Many thks to gearbest for sending me the device to play
    Many Thks to my beta testers trebor
    READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
    Changelog SCV1:
    • Simple rom, it still have default launcher etc...
    • Fixed Google logins, give it up to 5 secs for it to open when you press login... dont go crazy and start pressing like a ... well... you know...
    • Optimized the max i could.
    • Fixed some little stuff
    • Added google assistant Long press home to open it ( "Ok Google" anyone lol, i only tried with Minix A3 remote and works great )
    • Added double press home button to bring app switch... use the left or right arrows of the remote to close the open apps...
    • And a lot of others sh*ts...
    • Enjoy it
    Bugs SCV1:
    • Many more i bet........ but must i simple cant fix myself with out the source, so that i leave to beelink!
    Download:
    Install instructions:
    • Use beelink method, just check their forum...
    Where to buy:
    THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
    USE AT YOUR OWN RISK!
    Enjoy it!
    Any chance this will work on the Eachlink H6 mini?
      I really dont know!
        I tried. It didn’t load unless I did something wrong.
          bonjour superceleron, gr?ce ? votre ROM j'ai pu enfin ressortir du placard (juin 2018) ma box beelink gs1. a la base cette box est totalement inutilisable avec la rom beelink.
          j'ai 3 box beelink (GT1-GS1-GT1 mini) aucune avec la rom beelink car vraiment pas stable du tout. l'image parait de meilleur qualit? par rapport a la gt1. un seul petit soucis
          c'est au niveau du son,pas possible de le g?rer a la telecommande, obliger de me servir des boutons du casque ou haut parleur bluetooth. et aussi la mise en veille programm? de la box qui n'existe pas. dommage. a part ?a NIKEL encore merci pour votre travail
            Hi,I install this rom,flash is ok,boot with no error.Went boot I notice some bugs,Cant find my city, only cyrcle flow.Some flickering .Other side I Install Kodi 18 rc5 beta,works,in 106no stock rom the Kodi crashes.Pls.Celeron fix this bugs.This your rom is fluid,buth some bugs you must fix ,go to stock vr106no rom.
            Poslano sa mog MI 8 SE koristeći Tapatalk
            • superceleron
              superceleron commented
              Editing a comment
              I cant fix that city weather problem, that is because that launcher is uses a old weather api... just install Nova launcher and then some weather app and put a widget in main screen.
              The flicking cant nothing about it, is HDMI problem, try this disconnect the hdmi cable and reconnect it, and it should be ok!
            Ok.Thanks I will try.
              When you will make scv II Rom? This box is ok for me,because the wi fi signal is the best I goth.I hawe 5 tv box, the wi fi is wery bad.This box hawe the best wi fi.!
              • superceleron
                Editing a comment
                It all depends on beelink!
                If they do a newer build from the sdk, then i will do a SCV2!
              Why I cant install build on Kodi 18 leila,when unzip the file and install,File is not a zip file,and Kodi 17.6 do haw install this build? Where is the problem?
                Hello.
                Is this ROM valid for all versions of GS1? (different memory sizes) Thanks
                  Originally posted by dalpihe View Post
                  Hello.
                  I hawe 2gb 16gb and work.
                      Hi,haw to fix the the clock and weather location?
                        I think you need to change weather application but I don't know how to put it on starting window
                          Download:
                          Enjoy it!
                          Download link doesn't work for me. Could you provide mirror ?
