Huawei CF33 Moonlight Selfie Stick - Illuminate Your Beauty
    The Huawei CF33 selfie stick comes with the integrated LED light, positioned just under the smartphone holder, that will enable you to capture amazing photos and selfies even in a low light environment. This selfie stick remotely connects to your smartphone via Bluetooth connection, and it can securely hold all smartphones with screen size from 4.7 inch to 6 inch.
    Product Features:
    ● With integrated LED multicolored light.
    ● Suitable for all smartphones with 4.7'' - 6" screen size.
    ● Built-in fill light design, take bright and beautiful selfies in low-light conditions with less noise and natural skin color.
    ● Three gear adjustable brightness for different scenarios.
    ● One press switch, long press for on-off switch and short press for brightness switch.
    ● Remotely connects to your smartphone via Bluetooth connection.
    ● Extends from 18.5 to 61cm, for both close-up and panoramic shots.
    ● Compatible with all Android 5.0+ and iOS 8.0+ devices.
    ● Stable and durable aluminum alloy anodizing telescopic rod.
    ● Li-ion battery with Type C charging port.
    ● It could be used for flashlight and table lamp.
    Visit this Huawei CF33 selfie stick on GearVita, its simple, stylish, elegant design and thoughtful functions will definitely attract you. With the extreme compact body, it is perfect palm and bag friendly for easy portability: https://gearvita.com/huawei-cf33-moo...fie-stick.html
    You may like:
    buy xiaomi poco f1 lte 128gb
    buy xiaomi lyej05lm
    What's the price in AUD?
      It is about A$41.33. There is currency switch on our website, the Australian dollar conversion is included, you can check it here:
Name:	Currency Conversion.png
