Xiaomi CC05ZM Car Charger - 18W Quick Charge, Dual USB Ports
    This Xiaomi CC05ZM car charger features 18W fast charge, dual USB 5V 2.4A ports, allow to fast charge 2 devices simultaneously. It can provide the fastest possible charge up to 2.4A single port, which enhances the charging efficiency and decreases the charging time. With intelligent current distribution, it can intelligently adjust the current output according the needed power of different devices. It can provide multiple circuit protections, including over-temperature protection, over-voltage protection, over-current protection, short-circuit protection, anti-electromagnetic interference, safe and reliable!
    Product Features:
    ● 18W Fast Charging
    Double USB DC 5V 2.4A ports, allow to fast charge 2 devices simultaneously. Any single-port output can provide 18W fast charging for smart mobile devices, which enhances the charging efficiency and decreases the charging time.
    ● High Performance Circuit Master Chip
    The use of high-quality circuit chips, with 5 circuit protection of over-temperature protection, over-voltage protection, over-current protection, short-circuit protection, anti-electromagnetic interference. Not only improves the charging efficiency, but also better protects the car and charging equipment.
    ● High Battery Conversion Rate
    Built-in smart chip, which can intelligently allocate the required power for the charging device, and can control its own temperature even when working at high current.
    ● Dual Ports Intelligent Distribution
    When the dual ports are output at the same time, Xiaomi car charger can charge two devices and intelligently distribute, the total power can reach 15W max, easily cope with the need of simultaneous charging of main and co-pilot driver.
    ● Moonlight White LED Light
    In order to facilitate nighttime use, there is a LED light on the top, and the moonlight white soft light clearly indicates the position of the interface.
    ● High-end Material
    Made of premium copper, solid, durable, top-grade, beautiful and fashionable. The copper shell also contributes greatly to the heat dissipation, making the device always cool throughout the work.
    ● High Compatibility
    The matal elastic contact design is compact and stable, and can be adapted to different sizes of cigarette lighter and power interface. It can carry 12V/24V two voltages, and is compatible with mainstream vehicle types in the market.
    As a charging accessory in the car, the Xiaomi CC05ZM not only supports fast charging but also is equipped with a lot of modern technology. Priced at only $14.24 on GearVita, combined with classy design, it will be a great gadget for your beloved car: https://gearvita.com/xiaomi-cc05zm-c...e-edition.html
    You may also be interested in:
    xiaomi mi 8 lite 64gb
    xiaomi mijia quartz waterproof smartwatch
