Xiaomi Mi Portable Mouse Gives You An Accurate and Efficient Sense of Use
    Xiaomi mi portable mouse adopts dual reliable wireless transmission technology - 2.4G and BT 4.0, so that you can connect 2 computers, just press the button at the bottom of the mouse can be switched freely between the two computers. High precision laser optical sensor with DPI up to 1200 for smooth and accurate tracking on almost any surface. Compact size and perfect for office or home users.
    Product Features:
    ● Small size and light weight, only weights 77.5g including battery, portable.
    ● Environmentally friendly ABS plastic and smooth aluminum alloy shell that is minimalist and high-performing while being resistant to scratches, fingerprints, and impacts.
    ● Simple and elegant appearance, uses exquisite sand-blasting technology, more wear-resistant and corrosion-resistant.
    ● The front button requires just 0.6N of pressure for maximum comfort and performance.
    ● Supports Bluetooth 4.0 and 2.4G wireless connectivity, which can connect to two computers, and easily toggle between connections by pressing the bottom button.
    ● Adopts Nordic 51822 Bluetooth chip, with faster transmission and lower power consumption at the same time.
    ● Offers 10 meters max wireless coverage, and comes with high-speed laser positioning, the coverage is up to 95% including mouse pads, desktops, cloth, and glass.
    ● Features a photoelectric sensor that implements advanced laser technology, creates a higher contrast on most surfaces and allows up to 1200dpi for optimal office and entertainment use.
    ● Gently rotate to remove the battery cover, it includes 2 high-quality AAA batteries.
    ● The rounded ergonomic design is suited to both right- and left-handed users. ABS creates just enough friction for a firm hold and extended use.
    A touchpad isn't always enough for some tasks, this where Xiaomi portable mouse comes in. Compact and lightweight design makes it easy to carry around, this is the perfect lightweight solution in your pocket or bag. With the Xiaomi portable mouse on GearVita, you'll always be able to efficiently use your laptop and tablet on the go: https://gearvita.com/xiaomi-mi-porta...nectivity.html
    Hot sale products:
    xiaomi mini subwoofer bluetooth speaker
    mi mix 3 128gb smartphone
