did you "eraseFlash" before flashing the Rom ??? , Dev. Mo123 gave that Hint in his Rom
Thread , same CPU , so maybe same Bug ,
did you clean data/cache of the Playstore Apps , reboot , try again , this sometimes helps ,
maybe first a update over Aptoide is needed ??? really dont know , but hope you can fix it ,
good luck / gefattern
