Specification as found
CPU: Intel GEMINI LAKE Celeron N4100 Core: 1GHz,Quad Core GPU: Intel HD Graphics 600 RAM: 4G RAM Type: DDR4 ROM: 64G Max. Extended Capacity: SD card up to 128GB (not included) TV Box Features: 5G WiFi |
Decoder Format: HD MPEG4 Video format: 4K,AVI,H.265,MKV,MP4,RMVB Audio format: AAC,ACC,APE,OGA,WMA Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: DC 12V,Earphone Jack,HDMI,LAN,SD Card Slot,USB3.0,VGA HDMI Version: 2.0 Other Functions: Others Power Consumption.: 36w RJ45 Port Speed: 1000Mbps |
Power Type: External Power Adapter Mode Power Input Vol: 12V Suggest Input: 12V 3A Power Adapter Input: 100-220V / 50-60Hz Power Adapter Output: 12V 3A |
Product weight: 0.4000 kg Package weight: 1.2500 kg Product size (L x W x H): 18.00 x 18.00 x 3.00 cm / 7.09 x 7.09 x 1.18 inches Package size (L x W x H): 25.00 x 25.00 x 10.00 cm / 9.84 x 9.84 x 3.94 inches |
Package Contents: 1 x Tanix TX88 Mini PC, 1 x Power Adapter, 1 x English User Manual, 1 x Mini PC Bracket, 1 x 20cm HDMI Cable, 1 x 80cm HDMI Cable |
