X96S Wireless Display Dongle 2/16GB A8.1 Amlogic S905Y Dual WiFi BT4.2
    X96S Wireless Display Dongle: Android 8.1, Amlogic S905Y Dual WiFi, BT4.2
    Click image for larger version  Name:	1543041172768932.jpg Views:	2 Size:	142.0 KB ID:	752550
    Specification as found
    Type: TV Dongle
    GPU: ARM Dvalin MP2
    System: Android 8.1
    CPU: Amlogic S905 Y2
    Core: 2.0GHz,Cortex A53,Quad Core
    RAM Type: DDR4
    Max. Extended Capacity: TF card up to 64GB (not included)
    Decoder Format: H.263,H.264,H.265
    Video format: AVI,ISO,MKV,MOV,MPEG,MPG,RM,WMV
    Audio format: AAC,FLAC,MP3,OGG,RM,WMA
    Photo Format: BMP,GIF,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    Power Supply: USB Port
    Interface: DC Power Port,HDMI,IR,TF card,USB3.0
    Antenna: Yes
    Camera: Without
    Language: Multi-language
    DVD Support: Yes
    HDMI Version: 2.0
    Other Functions: 3D Games,3D Video,DLNA,ISO Files,Miracast,NTSC,PAL
    External Subtitle Supported: Yes
    Power Type: USB Port Supply
    Remote Controller Battery: 2 x AAA Battery ( not included )
    Product weight: 0.0310 kg
    Package weight: 0.3000 kg
    Product size (L x W x H): 10.00 x 3.30 x 1.30 cm / 3.94 x 1.3 x 0.51 inches
    Package size (L x W x H): 15.30 x 10.20 x 5.60 cm / 6.02 x 4.02 x 2.2 inches
    Package Contents: 1 x Dongle, 1 x HDMI Cable, 1 x IR Line, 1 x Remote Control, 1 x Micro USB Cable, 1 x USB Adapter, 1 x English Manual
    Gearbest
    X96S Wireless Display Dongle:?Android 8.1, Amlogic S905Y Dual WiFi, BT4.2
