Login blocked by captcha
I am connecting over tor from Indonesia. Many sites and services are blocked here so some sort of randomised global access is needed. I use an encrypted dns which unblocks a lot but do frequently have problems with cloudflair. They seem to run it to actively block sites over tor, but many of us have little other option.
We really shouldn't have to connect via vpn to specific regions or have tor blocked.
This is only happening to you, most likely, the problem comes from a software or setting on your computer, because for everyone else everything seems to be fine. I would try to clear the cookies, or another browser, because this is the reason, in my opinion. If it doesn't work, using proxycrawl might be a solution, because it avoids the captcha of the website and in this way, maybe you will be able to log in. There is a free trial, so you could try and see if it works, and you can extend afterwards if you like it.Last edited by Laratrak; 22 July 2021, 17:25.
Originally posted by Laratrak View PostThis is only happening to you, most likely, the problem comes from a software or setting on your computer, because for everyone else everything seems to be fine. I would try to clear the cookies, or another browser, because this is the reason, in my opinion. If it doesn't work, using proxycrawl might be a solution, because it avoids the captcha of the website and in this way, maybe you will be able to log in. There is a free trial, so you could try and see if it works, and you can extend afterwards if you like it.
There are currently 1725 users online. 0 members and 1725 guests.
