Beelink GT1 Mini TV Box with Air Mouse, Meet Your Google Assistant
    Beelink GT1 Mini Android TV Box is powered by Amlogic S905X2 microprocessor with four-core Cortex-A53, integrated graphics accelerator quad-core Mali-G31MP2. It works on the new version of Android 8.1, which fixed the previous bugs and still allows you to run any program. The interface design is convenient and easy to use - large tiles, horizontal screen shift.
    Instead of the remote control complete with a prefix there is an air mouse. The air mouse is much more convenient than a conventional remote, and has a large number of functions. The mouse in the box with this console has voice control, can be integrated with Google Assistant and includes a 6-axis gyroscope. Works through a 2.4 GHz connection, the signal transmits stably, without interference and interruptions.
    The new graphics accelerator allows you to stably watch videos in any format, including 4K, at 60 frames per second, the previous model of this accelerator usually provided comfort for only 30fps.
    Main Parameters:
    System: Android 8.1
    CPU: Amlogic S905X2 Quad Core Arm Cortex-A53
    GPU: Quad Core Arm Mali-G31MP2
    RAM + ROM: 4GB RAM + 64GB ROM
    Max. Extended Capacity: 64GB
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    WiFi: 2.4GHz + 5.8GHz Dual Band WiFi
    Bluetooth: Bluetooth 4.0
    RJ45 Port Speed: 1000Mbps
    System Bit: 64Bit
    Language: Multi-language
    Product Features:
    ● Smaller Than A Business Card
    14% smaller than the business card, small and fashion.
    ● 2.4GHz Air Mouse
    Air remote mouse with 6 axis gyroscope, 2.4G wireless fidelity voice input.
    ● Amlogic S905X2
    This Amlogic S905X2 processor fully supports premium 4K UHD video, the powerful 64bit CPU and G31 MP2 Graphics GPU combination handle 4K graphics better than most products on the market.
    ● DDR4 4GB RAM + eMMC 64GB
    It uses a DDR4 4GB RAM and an eMMC 64GB for better performance, security and reliability.
    ● Android 8.1
    Beelink GT1 MINI is one of the first TV Boxes to run on Android 8.1 (an update to Oreo), this software update allows for a great user experience with steady performance.
    ● 2.4G/5G Dual Band WiFi
    With support for 2.4GHz and 5GHz band, it can transmit higher amounts of data, faster and more stable.
    ● Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second.
    It is quite unusual for devices in this price category to equip with an air mouse for the price on GearVita is $72.99: https://gearvita.com/beelink-gt1-min...-64gb-rom.html
    There are also other two versions for you to choose from:
    Beelink GT1 Mini TV Box 4GB 32GB: https://gearvita.com/beelink-gt1-min...-32gb-rom.html
    Beelink GT1 Mini TV Box 2GB 32GB: https://gearvita.com/beelink-gt1-min...-32gb-rom.html
    You may also interested in:
    xiaomi mi box s global version
    xiaomi redmi 6a global version
