I've an A95x tv box equipped with the amlogic s905 1gb+8gb. I recently bought an sd card 64gb to use as internal storage but i discovered that is impossible (as in android 6.0 or 7) to use this space to save applications etc. formatting the card as internal space (move apps to sdcard doesn't work) .
So i decided to update to tha latest version of android, but i can't find the right firmware for my box. Can you guys suggest an official or custom firmware based on android 6 o 7 or superior and where to download it?
Am i stuck on lollipop?
:S
