MINIX NEO N42C-4 Mini PC with Pre-installed Windows 10 Pro
    MINIX NEO N42C-4 is powered by Intel N4200 processor with integrated Intel HD Graphics 505 which is the ideal for industrial and commercial applications. It delivers all the power and functionality of a desktop computer in a compact, stylish chassis. Achieving premium, ultra-responsive performance and the power to fulfil your productivity needs. Pre-installed with Windows 10 Pro (64-bit), set up is effortless and MINIX NEO N42C-4 is ready to run straight out of the box.
    Main Parameters:
    Processor: Intel Pentium N4200 (64-bit)
    GPU: Intel HD Graphics 505
    Operating System: Windows 10 Pro (64-bit)
    Memory: 4GB DDR3L
    Storage: Built-in 32GB eMMC 5.1 (MLC)
    Storage Expansion: 1 x 2280 M.2 slot (SATA 6.0Gbps) [support up to 512GB]
    Wireless Connectivity: 802.11ac Dual-Band Wi-Fi, Bluetooth 4.1
    Product Features:
    ● Great Design
    Its sleek and understated design allows for easy integration in any places with limited space, while still achieving premium, ultra-responsive performance and the power to fulfil your productivity needs.
    ● OS
    Pre-installed with Windows 10 Pro ( 64-bit ), set up is effortless and MINIX NEO N42C-4 is ready to run straight out of the box.
    ● Ultra-high Definition 4K
    Thanks to its Intel HD Graphics GPU engine, NEO N42C-4 excels at producing super detailed, crystal-clear 4K@ 60Hz imagery, capable of streaming ultra-high definition vibrant visuals smoothly.
    ● Triple-display Ready
    Allowing easy connection for up to three displays with the HDMI, Mini DisplayPort and USB-C outputs. ( the integrated USB-C port only supports video output, not audio output ).
    ● Storage Expansion
    MINIX NEO N42C-4 comes with 32GB eMMC internal storage and 4GB of DDR3L, while the inclusion of a 2280 M.2 slot ( SATA 6.0Gbps) and a pair of SODIMM slots ( dual channel support ) offer the flexibility to expand the storage and RAM to meet user's requirements. The 2280 M.2 slot ( SATA 6.0Gbps ) provides storage expansion up to 512GB, and the pair of SODIMM slots support up to 8GB of DDR3L memory each.
    ● Minimal Noise, Zero Disturbance
    NEO N42C-4 employs an active cooling solution to ensure safe operation and stable performance even throughout prolonged operation, while producing absolute minimal noise to guarantee zero disturbance during usage.
    ● Anti-overheating Chassis
    The chassis incorporates clevery disigned ventilation and air holes to maximize airflow, and maintain appropriate temperature to safeguard againt over-heating.
    ● VESA Mount
    INIX NEO N42C-4 includes a VESA mount for easy installation on the back of a VESA compatible TV or monitor, no tools are required for mounting once the included bracket has been installed.
    ● Business Friendly Features
    Built in accordance to industrial standards, NEO N42C-4 is highly reliable throughout periods of continuous 24/7 operation. An auto power=on option can be enabled whitin the BIOS menu settings, removing the need to manually power back on after a power outage.
    Most of the cheap Mini PCs on the market are preloaded with the Windows 10 Home version. If you need the Pro version of the business function, you will need to pay for an additional upgrade. The MINIX NEO N42C-4 is one of the few affordable models preloaded with Windows 10 Pro. The offer price on GearVita is only $266.99, which is even cheaper than buying the Windows 10 Pro retail version, it can be said that buy system to send a computer: https://gearvita.com/minix-neo-n42c-...-32gb-rom.html
    You may like:
    cheap xiaomi mi a2 lite smartphone
    cheap xiaomi mi max 3 4g smartphone
