Xiaomi Huami Amazfit Bip - The Most Popular Smartwatch on GearVita
    The Xiaomi Huami Amazfit Bip is equipped with the IP68 standard which makes it fully waterproof, so you can use it under the rain or even when you swim because it can resist to 30m underwater. The watch has a color LCD display which shows info with a resolution of 176 ? 176 pixels. It is a reflective panel which will allow you to save battery while it is in stand by, as it will still be able to show you what time is it. It has a heart rate sensor and a GPS + GLONASS module, as well as Bluetooth in the version 4.0, which can allow you to pair it with your phone.
    The Huami Amazfit Bip can also show notifications from the phone as every good smart watch. It has an accelerometer and a barometer sensor as well. Its battery has a capacity of just 190mAh but it has an outstanding battery life. The watch can last 45 days of daily use if you set the brightness to 10 percent. You can track your runs (indoor and outdoor), cycling and other sports with detailed GPS routes and stats.
    Product Features:
    ● 1.28? Touch Screen
    Equipped with a display size of 1.28 inch with HD resolution of 176 ? 176 pixel, protected with 2.5D Gorilla glass with AF coating, best suitable screen size with high definition picture displaying gives you great experience.
    ● Reflective Display Technology
    The dial is always bright without black screen. Uses reflective display technology, the dial brightness will auto adjust according to the environment. The sunlight reflecting technology allows you to clearly see the picture and read text even under direct sunlight.
    ● Lightweight Design
    The watch body is made of polycarbonate, which is super lightweight and highly resistant to physical damage. Weighing only 32g, it is comfortable to wear for a whole day.
    ● Sturdy Body with IP68
    The Amazfit Bip is designed for demanding users who will not save them. Thanks to the IP68 immersion, the watch immerses the water so you do not have to worry about sports under unfavorable conditions.
    ● Up to 45 Days Long Duration
    Built-in 190mAh Li-Polymer battery provides up to 45 days standby time on a single charge.
    ● GPS + GLONASS Dual Positioning
    Built-in Sony 28 nanometer low-power GPS chip, GPS + GLONASS quick and accurate dual mode positioning, keep track of your activities even if the smart watch is not around.
    ● Heart Rate Monitor
    Built-in PPG heart rate sensor, monitor your real-time heart rate in sports, make your exercise more scientific and effective.
    ● Sleep Tracking
    Carefully monitor your sleep quality, analyze your sleep patterns. Measures total sleep, light sleep, deep sleep and awake times.
    ● Information Push
    Push instant information, such as Facebook, Wechat, WhatsApp, let you real-time receive information.
    ● Call Reminder
    When a call or a message is coming, the watch will remind you via vibration, never miss any important call or message.
    ● Bluetooth 4.0
    Connected with mobile phone App, stable, fast and super low consumption.
    ● Multiple Sports Mode
    Support four sports mode: outdoor run, indoor run, ride, and walk. In different modes, you can view detailed sports data such as exercise duration, speed, maximum speed, distance, real-time heart rate, uphill and so on.
    There are 4 vibrant colors for option on GearVita - Black, Gray, Green and Orange, pick one up in your choice, with the price of $56.6 by using the coupon code "HMBIP": https://gearvita.com/xiaomi-huami-am...l-version.html
    You may like:
    xiaomi huami amazfit 2 stratos
    xiaomi mijia quartz waterproof smartwatch
