Notes:
- This was obtained by reading the raw partitions from media directly using the Amlogic update USB tool v1.3 and the Worldcup drivers.
- I've verified that the uncompressed IMG file writes back to the device using USB Burning Tool v2.1.2 and boots through setup, but not much beyond that.
- The reset switch for this device is in the audio jack, so make sure it's depressed when you insert the USB OTG cable in the USB 2.0 port.
Also, here's the build.prop:
# begin build properties # autogenerated by buildinfo.sh ro.build.id=OPM1.171019.011 ro.build.display.id=u211-userdebug 8.1.0 OPM1.171019.011 V0828.20181109 test-keys ro.build.version.incremental=V0828.20181109 ro.build.version.sdk=27 ro.build.version.preview_sdk=0 ro.build.version.codename=REL ro.build.version.all_codenames=REL ro.build.version.release=8.1.0 ro.build.version.security_patch=2018-06-05 ro.build.version.base_os= ro.build.date=Fri Nov 9 15:52:37 CST 2018 ro.build.date.utc=1541749957 ro.build.type=userdebug ro.build.user=weizhongyi ro.build.host=vstrong3 ro.build.tags=test-keys ro.build.flavor=u211-userdebug ro.product.model=KM9 ro.product.brand=Amlogic ro.product.name=u211 ro.product.device=KM9 # ro.product.cpu.abi and ro.product.cpu.abi2 are obsolete, # use ro.product.cpu.abilist instead. ro.product.cpu.abi=armeabi-v7a ro.product.cpu.abi2=armeabi ro.product.cpu.abilist=armeabi-v7a,armeabi ro.product.cpu.abilist32=armeabi-v7a,armeabi ro.product.cpu.abilist64= ro.product.manufacturer=VS ro.product.locale=en-US ro.wifi.channels=11 # ro.build.product is obsolete; use ro.product.device ro.build.product=u211 # Do not try to parse description, fingerprint, or thumbprint ro.build.description=u211-userdebug 8.1.0 OPM1.171019.011 V0828.20181109 test-keys ro.build.fingerprint=Amlogic/u211/u211:8.1.0/OPM1.171019.011/V0828.20181109:userdebug/test-keys ro.build.characteristics=mbx,nosdcard # end build properties # # ADDITIONAL_BUILD_PROPERTIES # ro.bionic.ld.warning=1 ro.treble.enabled=true persist.sys.dalvik.vm.lib.2=libart.so dalvik.vm.isa.arm.variant=cortex-a9 dalvik.vm.isa.arm.features=default dalvik.vm.lockprof.threshold=500 net.bt.name=Android dalvik.vm.stack-trace-dir=/data/anr ro.expect.recovery_id=0x15cb39bab8d9df530ec8a67088eb7377e0f43cea000000000000000000000000
