Xiaomi Mi 4 Ports USB Charger - More Convenient and Fast Charge
    Do you always have trouble finding enough charging points in a hotel, a hostel, a stay at home or a place where you stay while traveling? No longer! Xiaomi Mi 4 Ports USB Charger is here to make your life easier. It has 2A fast charging technology which means it needs less time to charge than before. With protection against overvoltage, input and output protection against overcurrent, protection against short circuits, protection against overtemperature, antielectromagnetic protection and protection against electromagnetic discharges totally safe and harmless for your device and your battery. The small size at 65 ? 61.8 ? 28mm is the best for outdoor activities!
    Product Features:
    ● 4 USB charge ports, single port support 5V/2.4A output, with total power of 35W, can charge 4 devices at the same time.
    ● Using Fairchild (Fairchild USA) smart chip, compatible with computers, cameras, and other hardware products.
    ● Easily control multiple devices at the same maintaining high-speed 2A fast charge, ensures charging less time than ever before.
    ● International AC100-240V wide voltage input and 50/60 Hz voltage frequency to meet the different countries and regions, charge without borders.
    ● Multiple protection features work together to provide ultimate protection for your devices and chargers.
    ● All-in-one design with a foldable plug, more space-saving and well-organized while charging, no more worrying about the chaos of the cable.
    The $14.24 Xiaomi 4 ports charger on GearVita lets you keep all of your mobile devices charged and ready to use, regardless of where you?re located: https://gearvita.com/xiaomi-mi-4-ports-usb-charger.html
    You may like:
    cheap xiaomi mi mix 3 128gb
    cheap elephone w3 smartwatch
    Click image for larger version  Name:	Xiaomi-Mi-4-Ports-USB-Charger-1.jpg Views:	1 Size:	48.9 KB ID:	753473
