Sunvell T95Q TV Box - Designed around 3D Life
    The Sunvell T95Q TV Box includes the Amlogic S905X2 SoC a Quad Core that theoretically reaches up to 2GHz and integrates a GPU ARM Mali-G31 MP2 quite more powerful than the classic Mali-450. It has 4GB of LPDDR4 RAM and 64GB of eMMc storage memory that can be extended from the microSD card reader included in this box. T95Q is also equipped with wireless connectivity dual band WiFi and bluetooth 4.2 and installed system is Android 8.1 in its classic version.
    In the connectors, there are a USB 2.0 port, another USB 3.0, analog audio and video output port, a Gigabit Ethernet connector, SPDIF digital audio connector and HDMI 2.0 video output.
    Product Features:
    ● Android 8.1 operation system
    ● Amlogic S905X2 CPU, quad core, Cortex-A53, 2GHz
    ● Davlin MP2 GPU
    ● 4GB DDR4 RAM + 64GB ROM
    ● 2.4GHz + 5.8GHz dual band WiFi
    ● Support 4K ultra high definition
    ● Support H.265 decoding, DLNA, Google TV remote, LAN, 3D movie
    It is a good chance to get it from GearVita with the price of $65.99: https://gearvita.com/sunvell-t95q-tv...-64gb-rom.html
    There is also another version for you to choose from:
    Sunvell T95Q 32GB: https://gearvita.com/sunvell-t95q-tv...-32gb-rom.html
