can anyone help me about type of my android box?
    hi all nice to meet you. im new on this forum and i apologize for my english...isnt so good.
    lets start i bought 1 box and i dont know what box it is i mean model ,etc. can any1 help me? i upload some photos here.
    i need to know what box it is because i want to change rom-firmware with one from here if exist!
      Hi ,
      the best is to open up and look and take Pictures ,
      greetings / gefattern
        Hi ,
        thanks for your help.i open it and i take this pictures. can you help me?
          Hi ,
          the Sticker on the back says it is a T95M 2GB/....GB , so you know it ,
          is it bricked ??? greetings / gefattern
            Hi ,
            no sir its not bricked,i just wanna root it again cuz i unroot it for no reason... is there a method for root? or the easiest way is to install a new rom? and where can i found it for this box?
              Hi ,
              think well it is possible to "root" your Box , for sure there are "rooted" Roms , but the Specs must be the same ,
              like WifiChip ..... , it has a S905 CPU , or ??? , maybe the atvExperience Rom for this SOC ??? , but to be sure first
              read & ask in the Threads about atvEx.... ,
              good luck / greetings / gefattern
                thanks you very much sir. yes it has S905 cpu
                  im so confused... my cpu is s905x4 if i download rom from atvExperience for s905x its the same?
                  i mean s905x and s905x4?
                    Hi ,
                    there are the old S905X and newer S905X2 CPUs , think yours is the X Version ,
                    the 4 only stands for the Cores , i think , good luck , report your results ,
                    remember always ask in the Thread , before you want to flash this specific Rom
                    to your Box ,
                      thanks you again sir!i install atvexpiriance rom but i dont like atv style!i will search now for android rom!
                        Hi ,
                        to your Box ,
                        hey sir is there roms without ATV?cant find...is there a link? as i can see the last roms its only ATV.i dont like atv roms i just wanna android rom
                          Hi ,
                          think well , but you must search for your self , because i do not have this Box , best to read
                          the possible Threads , most Users are linking other Roms too , maybe it is possbile to change
                          the stockLauncher of the ATVRom with a normal Launcher , that you like , but for this you must
                          ask the specific Dev. , hope you get one , good luck / gefattern
