TANIX TX88 Gemini Lake N4100 Windows10 4GB 64GB Mini PC
    TANIX TX88 Gemini Lake N4100 Windows 10 4GB DDR4 64GB eMMC Mini PC Dual Band WiFi Gigabit LAN USB3.0 Support Cortana HDMI + VGA
    Ship from China.
    Intel Gemini Lake N4100, Quad Core
    The Intel Pentium N4100 is a quad-core SoC running at 1.1-2.4 GHz. The chip is manufactured in a 14 nm process with FinFETs, double the amount of L2 cache. Besides four CPU cores, the chip also includes a DirectX 12 capable GPU as well as a DDR4/LPDDR4 memory controller (dual-channel, up to 2400 MHz).
    Pre-installed Windows 10
    TANIX TX88 Mini PC is pre-installed with Windows 10 home, so that our users are able to enjoy the advanced functions of Windows OS directly. Moreover, the built-in Cortana in Windows 10 can turn TANIX TX88 into a work assistant as well as life-partner. With Windows 10 OS, you can sync game display to any devices of Windows 10 OS.
    DDR4 4GB RAM + eMMC 64GB
    It uses a DDR4 4GB RAM and an eMMC 32GB for better performance, security and reliability.
    2.4G/5G Dual Band WiFi
    With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
    Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second.
    Check more info here.
    Get extra coupon for EU Stock now.
