REVEZ QDROID ANDROID TV BOX
Originally posted by tomotomo View Postcan anyone help me to get the right firmware for this box thanks motherboard number GP13400HA20150115 i think its base on the 4.4.2
for this we need more Info , CPU GPU , Wifichip , best , good quality pictures of PCB , both sides ,
but if it has 4.4.2 installed it sounds like it is a very old Box , maybe better to buy a new one , what
are your needs ???
greetings / gefattern
hi everyone thanks for your replys here is all i can get on the revez qdroid tv box i hope it helps
Revez Q-DROID Android TV Box (Quad Core, Android 4.4 KitKat, XBMC)
The processor in this android box is an ARM Cortex-A5 Quad Core with a maximum clock speed of up to 1.5GHz. Apps have never run so smoothly.
This model features built-in WiFi connectivity.
Memory:
The Q-DROID has a memory of 1GB DDR3. Supports micro SD card up to 32GB. If this is not enough you can also connect an external hard drive via USB, or use NAS.
Operating system:
This Android box is supplied with Android version 4.4 Kitkat. Android gives you access to over 800,000 apps including Facebook, Youtube, Picasa and many others. There is also a huge variety of games.
Ports:
The Q-DROID features two USB 2.0 ports and one micro USB OTG port. Support webcams and microphones to external hard drives and USB sticks. Furthermore, this box supports HDMI 1.4b connector, AV out, SPDIF to connect a home cinema, a Micro SD card slot and a jack for Ethernet, giving you the best possible connection. Also, there is an on / off button available.
Product Features:
Operating System:Android 4.4.2 Operating System Quad-Core ARM Cortex-A5 processor,Main Frequency 1.5GHz (DVFS) Graphics Processor:Quad-Core,ARM Mali-450 GPU Supports wireless network、2.4G mouse and keyboard WIFI Built-in(2.4G and 5G) Supports USB--3G Dongle Supports DLNA, MirCast,Airplay Supports DRM (DRM encrypted content protection technology) 10/100 MBit network port compatible Supports HTML 5 Supports weather forecast,show default weather information bar of the city Supports the web browser Supports web broadcast and IPTV agreement [http or rtsp, rtmp, mms] Supports Adobe Flash 11.1 player Supports H.265 DXVA Supports Google search and messaging Can uptate the software through USD 、SD card slot and network Supports a variety of popular applications and games under android system Supports file browsing
Technical Specifications:Video Video Standard: ISO/IEC 13818-2 MPEG1,MPEG-2 MP@ML,H.264, H.265,WMV/VC1 and MPEG4 Aspect Ratio: 4:3, 16:9 HD output,Built-in HD 1.4b Audio Audio Standards: ISO/IEC 13818-3 Sample Frequency:32, 44.1, 48KHz Supports the format of MP3,AAC,WMA,RM,FLAC,Ogg Audio Output :HDMI ,Audio L/R A/V Output Video De-emphasis: CCIR REC.405-1, 625 Lines Video Bandwidth: 5.5MHz Video Output Impedance: 75Ω Video Output Level: 1.0Vp-p Audio Output Frequency: 20Hz~ 20KHz Processor & Memory Processor: Amlogic S805 SDRAM Memory: 1GByte DDR3 Flash Memory: 4GByte NAND & 2MBytes SPI FLASH Front Panel Infrared Ray Reception: 38KHz or 2.4GHz 2LED Power Supply & Network Rear panel/Side Panel CVBS Stereo Audio: Left & Right Channel 2 USB Port HDMI Output, SD card slot, RJ45 Others Power Consumption:12W Standby Consumption <0.5W Power Supply:5V 3A or 12V 1.5A Adapter
Originally posted by tomotomo View Posthi everyone i think this is the wifi chip number RTL8199ETV E210E31 I HOPE THIS HELPS
really , i think it is better to invest 50-60? , for a new up to date Box then wasting your Time
with search for a ROM , for this old Box , like User "mitchell4you" advised u can try Linux or LE ,
good luck / gefattern
There are currently 2045 users online. 0 members and 2045 guests.
