Need to identify my Android Box and find firmware
Originally posted by neomode View PostHello,
This Information not help. Sure you have a Samsung Nand but that's not the Point.
What is the Name of your Box and the CPU?
Maybe you can Post a Picture of it, please.
Neomode
Pictures you can see in Post 1 , so it does not matter what kind of Chip is used , is this correct ??? ,
i think his Problem was , bought 2GB RAM Box , but it shows only one , or similar ,
greetings / gefattern
Hi ,
The Nand Chip Manufacturer has no matter.
They change it often.
It is like using an Hard Drive.
Different Manufacturer different speed.
That's all.
Neomode
Sorry did not see the first post.
That's all.
Neomode
good to know ,
so maybe one Chip is bricked or wrong Rom flashed , or fake Specs from Gearbest ,
but this is not possible , or ??? , greetings / gefattern
I would like to update the situation.
After some exchange of electronic correspondence with Gearbest, I was awarded some "ilarant" solutions. An example:
Please try the following method to figure it out:
1. Try another HDMI cable to see if it can work.
2. Press the power on button for 50 second and then turn it on.
3. Try another adapter to check if it can work.
4. Please kindly confirm the interface are in good condition, there may be oxidized and try to scrape it with the little blade.
Regrettably, none of the firmwares in that repository worked. In the end, Gearbest regretted what happened and recognized that, unfortunately, the product cannot be fixed. I must admit this is a shock to me. I'm not convinced.
Anyway, Gearbest offered me a full refund of the price, which was very positive of them.
There are currently 2183 users online. 0 members and 2183 guests.
