My device was working okay for the last one month. Yesterday I purchased an Magicsee air mouse and used fine. While switching on today, the wifi is not working. It is disabled and while trying to enable it , it enables for a few seconds and then automatically turns off. Tried the following but no success
1. Restarting device - No Wifi
2. Power cycle - No Wifi
3. Disabling Bluetooth, then restart - No Wifi
4. Enter ES file explorer - Root explorer - deleting data/misc/wpa_supplicant.conf - Restart - No Wifi
5. Unplugging USB devices - Restart - No Wifi
6. Factory reset - No Wifi
7. Data wipe & reset through Recovery - No Wifi
8. Ran the following commands using terminal emulator (a) su (b) svc wifi disable (c) svc wifi enable - Still no wifi
I can see that after factory reset no wpa_supplicant.conf file has been generated. Ethernet is working fine though
Can anybody help me in this regard?
