X96S Display Dongle/Stick A8.1 Amlogic S905Y2 Dual WiFi BT4.2
    X96S Wireless Dongle: Android 8.1 / Amlogic S905Y2 / 2.4GHz + 5.8GHz Dual Band WiFi / BT4.2 / HDR / Support 4K H.265
    Main Features
    ● Android 8.1 operating system
    ● Amlogic S905Y2 CPU, Quad core, ARM Cortex-A53, 2.0GHz
    ● ARM Dvalin MP2 GPU
    ● 2GB / 4GB DDR4 RAM + 16GB / 32GB EMMC ROM
    ● 2.4GHz + 5.8GHz dual band WiFi
    ● Support 4K ultra HD image display
    ● Support H.265 decoding
    COUPON:GBCNX96S $ 42.99 100PCS until 2019/1/31
    Gearbest
    Good day. Where to get the firmware for this box.
      Today thanks to our friends at Gearbest we can have a closer look at the
      Been awhile since we have seen a Dongle/Stick Device, this should be fun.
      Nifty little device by the looks, has a Remote and IR Extender cable.
      Also has a small HDMI cable M to F for easier access to HDMI port fitting.
      Power supply 5vDC 1.5AMP, with USB Cable, Most TV's today should be able to drive this, but nothing in guaranteed in life.
      Previous Boxes made by this Company (if the same) have been good, let's hope for the same.
      Let's Have a look see.
      The Box:
      What's in the Box:
      Ports: TF Card, Input Mini USB Port, Reset Button and IR Input
      Only one USB port, nothing a small USB Hub and fix if needed
      Pop the top: WiFI and Ram
      eMMC CPU under Slab of alloy:
      Previous 905Y2 tested ran cool as, let's hope for the same and most Stick Dongles have in the past run HOT
      One Side:
      Click it image, goes bigger
      Other Side:
      Click it Image, goes bigger
      More to come
      GEARBEST
        On with more show and tell
        Good little Startup/Animation
        Set up with Wizard Wifi and Google piece of cake,
        Interesting and Different UI as will be seen.
        Updated a couple apps and installed testers etc.
        Has Root access, No SU, also no Upper or Lower Bars.
        Remote is only OK, I find needs to be Inline with IR extension or NADA.
        Using Logitech k400 ok, Enter/Q problem easy fix.
        Found using Mouse on Logitech, the accuracy of clicking on Icons can be hit and miss to non existant thinks its an A8 thing.
        Run's a little warm small space not Air Flow to be expected.
        As Always,
        Benchmarks are just to give an Idea of what going on in the Unit,
        Lets have a look:
        Boot Video:
        Startup Wizard:
        UI, Installed Apps:
        All Up To Date:
          More On X96S Display Dongle/Stick A8.1 Amlogic S905Y2 Dual WiFi BT4.2
          Information and Tests
          Root Access:
          DRM: L3
          Ram and Storage Truth:
          Aida64: USB Info:
          SD Card test: little sluggish
          CPU-Z
            One more set of Numbers for those that like to see or who are playing at home on the X96S Display Dongle/Stick A8.1 Amlogic S905Y2 Dual WiFi BT4.2
            ANTUTU
            Geekbench
            WiFi:
            GFXBench:
            Aware that this is No 3D Power House: and we know this.
            There we have a bit of a look see of what we have and some testing
            Small Compact, working ok, will find a place behind someone's TV or Monitor.
            Not a power house, Social Games, internet, Easy
            Playing Of Videos etc has been noted in other threads and other can add if they wish:
            Thanks to Gearbest
            Gearbest
              Hi! Is it possible to Install Linux on it?
                Can it be unrooted?
                  This is the stock firmware :
                  Enjoy it!
                    I ordered this model, but with 2 gb ram, the Geerbest is presented as a model that has a 5.8GHz, but does not have that option only 2.4GHz.
                    Here nowhere to be seen whether this model with 4 GB ram has a 5.8 GHz wireless option.
                    I received a model with 4GB of ram and has a 5.8 GHz WiFi. Model with 2GB of RAM has only 2.4GHz WiFi.
                      Hello everyone I hope to be in the right place, I have a problem with my box, I should restore it but I need the firmware, the box is this: X96_mini_v1 Nucleo: Quad core
                      CPU: ARM Cortex-A7
                      GPU: Mali-400 MP
                      Modello: X96
                      RAM: 2G RAM
                      Tipo RAM: DDR3
                      ROM: ROM 16G
                      Tipo di Sciarba: TV Box
                      Processore: Rk3229
                      Help me for the firmware thanks
                        superceleron ,
                        Any chance for an ATV version for this stick? I've been using your ATV rom for my H96pro Mini for a couple of years and its been rock solid! Purchased on of these to retire my old stick.
                          sorry but no... at least from me, i dont have time or even have the device!
                            Awwwww.... thanks for the reply and keep up the good work!!! Cheers Mate!!
                              A Very detailed youtube testing link:
