Need stock player back...
Hi everybody thank you for this opportunity to use your website and flash your great roms!! I do have a question I fouled up my ugoo7b tv stick the other night trying to just root it, and ending up having to flash a rom due to me not rooting right. After extensive research finally found a rom that my wifi would work on. Which was neomode custom rom 1.3 which has the ap6210 wifi chipset, anyway it's up and running great. I just noticed that after the upgrade I have lost the native video player which had the pop out video function. I realize I can go for one of the ones from the play store I just like the interface along with being able to pop out video from the web. I did find a website with quite a few idea apks however I ,don't know which version I had nor what the correct name of it was.can anybody help me out here, I would be most grateful!! Thank ou in advanced. Here is the website that I found don't know if any on here are the right ones. http://www.filecrop.com/android-video-player.apk.htmlTags: None
Picture of video player wanted
Here is a pic of the player I had on stock rom of the ugoo7b stick http://www.laptopmag.com/images/uplo...0/rk3188-2.jpg. It's at bottom closest to the left of the pictured window. Many thanks.
There are currently 2738 users online. 2 members and 2736 guests.
