Did USB Burn Tool Work before, but now ..hours of fail??
Amlogic Worldcup Drivers..no longer installed properly???
Windows O.S. (7,8,10) ...Giving grief(I'll leave off on the insults)????
"USB Control setup error
"Path not found"
..so many others.
Amlogic Burn Tool: https://chinagadgetsreviews.com/down...ol-v2-1-6.html
I'm sure there are smarter people who can help you..so at your own peril.
- I've had only success using Amlogic USB Burn Tool v 2.05..17 or 2.06...17(forgetful)
- Disconnect from internet.
- Check USB Burn Tool logs...might have a hint to your troubles!
- Turn off antivirus and firewall if possible.
- Uninstall USB Burn Tool...in all locations that you may have tried to install.
- Manually go to these folders and delete files and all folders.( Keep your original install package if staying with same version).
- Uninstall World cup drivers..you will also need to go into Device Manager -show hidden devices and delete any mention to world cup drivers..
- Reboot. turn off Antivirus and firewall
- Check Device Manager again to verify World Cup drivers are gone...also look to USB Hub drivers for any funky type of driver items which might conflict.
- Install as Admin Amlogic Burn Tool ..careful..windows will try to install it's own drivers...fine but let the install program finish searching first...If you wait a World Cup driver prompt might pop up shortly also... I tried so many ways...well(forgetful).
- Try running USB Burn Tool...not successful..try rebooting and run tool again.
- After USB Burn Tool is installed, go into setup folder and find World Cup drivers folder.
- Right click and run the that setup as Admin.
- With Windows 8-10, you might have to consider "right clicking" on install package or "World Cup" drivers setup and select "Win 7 compatibility mode".
- Afterwards you can try also install World Cup drivers again via Driver.inf
- Remove any USB devices if possible, if keyboard is USB..keep it. My USB mouse caused a conflict with one of my installs.
- You may want to try a different computer USB port than the one you have been using...as a first try...if fail try another port.
- If you do not succeed, try rebooting.
- Hopefully you have success...if not...check your Device Manager to see if and where the World Cup USB drivers installed.
- (Really forgetful)....you might connect your China Box and force Windows to find New Device...choose manual install and select the World Cup drivers from your setup folder.
Wow look....still another attempt
- Having done a marvelous job of installing Amlogic USB Burn Tool....with a whole lotta fail..
- Run USB Burn Tool and set up your firmware as needed.
- Hold in reset button..insert power supply.
- Insert USB cable...keep holding reset button.
- Does Burn Tool see China Box? >yes press start button..keep holding reset button(?)
- Does Windows see device and start installing World Cup Drivers?
- Let O.S. Finish and hit the start button....(while still holding the reset button?)
*** I'm sure there are better equipped members to provide help***
P.S I believing in dictating to my cat ..who does his best with his cute fumbly paws!
.gif)
