Sent from my Firefly V65 using Tapatalk 4
Rk3188 Lag?
Rk3188 Lag?
Perhaps I've installed something that's causing this but after I install all my apps, I find the system really lags a lot and it takes a while for an app to load. I also noticed this on my Pipo M6. On my 1080p quad core phone I don't get this at all.Does anyone know if this is something to do with the Rk3188.
Sent from my Firefly V65 using Tapatalk 4Tags: None
Or perhaps the apps you installed... perhaps.. you can name them
Check whats running in the background...
Have you tried emtying 'cache' ?
Do you have enought emty space.. ? ( temp/cache)
I have two rk3188 but no lag..
I did notice.. when using xbmc with cache 0,
. when under settings it says 50mb.. but when emtying cache i see the bar drop allot (even while not using it)
One time -
I got notification 'running out of space'
Under storage 1.5gb free.. however.. when doing unmount all.. remount all.. nand-sd stated 700kb
Closing and emtying cache solved it (it was xbmc / cache0)
Anyway goodluck
Hi, it seems that I note this same issue with X7. Now, I works on 004 firmware version and after few apps installation (I don't investigate which one generate issue or not) I see a lot of lags in the system. I don't think that it is cache issue because lags appears right after starting the X7. Removing tasks not working. Maybe some system app generate this problem.
Re: Rk3188 Lag?
Originally posted by Dakan View PostHi, it seems that I note this same issue with X7. Now, I works on 004 firmware version and after few apps installation (I don't investigate which one generate issue or not) I see a lot of lags in the system. I don't think that it is cache issue because lags appears right after starting the X7. Removing tasks not working. Maybe some system app generate this problem.
Re: Rk3188 Lag?
After Finless 1.6 instalation. I must say - this is it. Lags issue gone. I am wondering what was the cause? But I remember that it happen (in firmware 004) after some apps instalation. In Finless 1.6, there are few system apps removed, so maybe this is it. Of course, I will spend more time to look at this issue in my X7.
However, if someone could check this issue in Minix firmware 005 it will be great.
Re: Rk3188 Lag?
Originally posted by Dakan View PostAfter Finless 1.6 instalation. I must say - this is it. Lags issue gone. I am wondering what was the cause? But I remember that it happen (in firmware 004) after some apps instalation. In Finless 1.6, there are few system apps removed, so maybe this is it. Of course, I will spend more time to look at this issue in my X7.
Sent from my Faea HY509S using Tapatalk 4
There are currently 2337 users online. 0 members and 2337 guests.
