2GB+32GB / 4GB+64GB For your reference.
Android 8.1
A95X MAX is one of the first TV Boxes to run on Android 8.1 (an update to Oreo). This software update allows for a great user experience with steady performance.
Amlogic S905X2
A95X MAX runs Android Oreo on Amlogic S905X2, an upgrade of its S905X predecessor with the same quad-core Cortex A53 cores paired with a ARM Dvalin MP2 GPU but adding VP9 hardware decoding, which is the absolute mainstream decoding formats around the global.
DDR4 2GB RAM + eMMC 32GB
It uses a DDR4 2GB RAM and an eMMC 32GB for better performance, security and reliability.
2.4G/5G Dual Band WiFi
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
True 4K Media Player
While your average media box might only accept 1080P video playback, this gadget plays just about any 4K source.
Buy Now!
