I had to unbrick my box using UART after I forgot to uncheck "erase bootloader" in the burn card maker. Both flashing the current stock image and flashing the current TVNexus image from SD card worked fine - but the box only boots to recovery after this process.
When a stock recovery is installed, it just boots to that and displays the "No command" background. When TWRP is installed, it always boots to that.
Does anyone have any idea how to fix this?
I attached the recovery and dmesg logs below.
EDIT: Alright, it seems like something just went wrong when previously flashing the images. I flashed the most recent stock image again today using sdc_burn and now the box seems to be working fine.
