Trouble booting Corelec on Mecool M8S Pro L?
I'm having trouble to get CoreELEC to boot on my Mecool M8S Pro L. I have installed Corelec on a micro-SD and used the right dtb.img but have no succes when booting CoreELEC. It always boots Android TV. What am I doing wrong?Last edited by Sjaool; 24 December 2018, 16:14.Tags: None
Originally posted by Sjaool View PostI'm having trouble to get Corelec to boot on my Mecool M8S Pro L. I have installed Corelec on a micro-SD and used the right dtb.img but have no succes when booting Corelec. It always boots Android TV. What am I doing wrong?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
bubblegum57 I'm Googlin' for a few days now but this is the first time I get some decent help. Thanks for that! I will fiddle some time with your suggestions.
I found the press the context menu button on you tube https://www.youtube.com/watch?v=45IIjk-UXTw&t=126s
Originally posted by bubblegum57 View PostI found the press the context menu button on you tube https://www.youtube.com/watch?v=45IIjk-UXTw&t=126s
[edit]
CoreELEC would not boot with the context button but now I used Librelec and it boots just by pressing the contex button!
CoreELEC is now bootiing too!
Next step is to get the remote to work. :P
[/edit]Last edited by Sjaool; 24 December 2018, 16:14.
bubblegum57 It's working fine now. Using the context button boots directly into CoreELEC. Is use Yatse as remote. Only thing is the voice remote which is not working so that is the next thing to fix. :PLast edited by Sjaool; 25 December 2018, 00:01.
bubblegum57 that's a pity. But Yatse works perfectly. Now I just need to find out how to start CoreELEC via Wake On Lan. With my old Asrock htpc it worked perfectly. However the Mecool M8S Pro L is something different.
Originally posted by bubblegum57 View PostYou could read this https://discourse.coreelec.org/t/h96...y-mode/1814/68
There are currently 1522 users online. 2 members and 1520 guests.
