[ROM] Beelink GT1 Mini Stock & Nano Nexus ROM (Android 8.1)
Guest
So, I'm considering dropping one of these non-ATV variants, either Nano or Stock. Anyone have a preference?
Does the stock variant have TWRP?
if not, the answer is simple.
I prefer Nano as it has more options.
#17.1Guest commented15 January 2019, 12:36Editing a commentBoth variants have TWRP. The Stock variant just has more Google apps...the ones that are included in the Stock variant of OpenGApps. Nano is really just the bare minimum, but you can always add the other Google apps via the Google Play Store.
Hi Magendanz - I always use a wired network connection and leave the mini switched on when i'm not using it - and I'm using static addressing.
I am finding that if left unused for a few hours the network connection fails and I have to reboot the box to get connection back.
Do have any suggestions?
Many Thanks
Hello all,
Thanks for this ROM, really frendliest than stock X96Max...
I flashed the NANO, but only was able to Flash from SD card because with USB, bootloader stops after few seconds...
I Just have few bugs :
1 : I'm actually not able to enter recovery... When I push the button, then connect usb to PC, USB Burning tool shows "connected" for 2 seconds and then, the ROM starts and "connected" status disappears...
2 : The LCD pannel on the box doesn't work, so I have no clock or light to show the box is ON
3 : The IR remote won't work properly.. buttons seems unassigned, so, impossible to power on the box with the remote, The ony way is to unplug AC power, then plug again...
4 : I don't know whitch recovery is installed and I'd like to in install superSU or Magisk but I don't know if I can ...
Please is someone that can help me ?
Thanks guys !
Sam.Last edited by s1der; 17 February 2019, 01:03.
Almost everything you listed above is due to the fact that this custom ROM was built for the GT1 Mini, not the X96 Max. That other device has different IR remote codes, different features (like an LCD display) and a different device tree. Someone needs to customize the ROM for your device (and I don't have an X96 Max).
- Magendanz commented
02-17-2019, 01:17
I now hope that someone will customize it for X96Max. :P
If you ear about it, I'm interested to know that
Thanks again !
I have just one more question :
I'm now trying to flash TWRP or stock rom but it seems impossible.
Connexion with PC with USB impossible and start over the SD card impossible too ....
Do you have any advice for me ?
THX !Last edited by s1der; 17 February 2019, 18:22.
If the box is rooted, you can install TWRP via "dd if=twrp.img of=/dev/block/recovery". Otherwise, I've created a signed OTA update here: https://1drv.ms/u/s!AoqocX31ecnXgbIdSaKxLK3e-SPboA
Yes, some features of X96 max dont work but the essential ones do. For reboot i installed a small app from Google play (a lot available). Navigation and status bar work perfect, not so in stock rom. This is important for me to open a browser for solving a recaptcha while loading a stream in kodi. And in the original rom the mouse did not work well so you needed to use the remote control: i prefer a good mouse support. The LCD panel i never missed:-) Thanks again Magendanz for that perfect Rom....i visited your affiliate page a lot of times again and would like other users to do the same...best is not only visit the page but do some actio, like clicking offers etc.
There are currently 2289 users online. 0 members and 2289 guests.
