A95X R1 s905w bricked
ID:	756046Click image for larger version
    hello
    i have an OTT box with s905w 1g/8g bricked after flashing wrong rom,now just bleu light nothnig on screen..
    i lost recovery, i have a bleu light led when on power and the box connect with usb burning tool but it always stop at 9%, i tried a lot of firmware but no one work. can somone help me fixing wthe probleme.
    the box came with 7.1.2
    i think i have probleme with bottloader partition
    here the log :
    [22:18:57 230][Global][Inf]--Scan USB host controller complete
    [22:18:57 230][Global][Inf]--Update data center with HubMap
    [22:18:57 230][Global][Inf]--Update hub1 device data
    [22:18:57 230][Global][Inf]--Update HUB1-1 \\?\usb#vid_1b8e&pid_c003#5&16bdd27b&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [22:18:57 230][HUB1-1][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-2
    [22:18:57 230][HUB1-2][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-3
    [22:18:57 230][HUB1-3][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-4
    [22:18:57 230][HUB1-4][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-5
    [22:18:57 230][HUB1-5][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-6
    [22:18:57 230][HUB1-6][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-7
    [22:18:57 230][HUB1-7][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-8
    [22:18:57 230][HUB1-8][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-9
    [22:18:57 230][HUB1-9][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-10
    [22:18:57 230][HUB1-10][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-11
    [22:18:57 230][HUB1-11][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-12
    [22:18:57 230][HUB1-12][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-13
    [22:18:57 230][HUB1-13][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-14
    [22:18:57 230][HUB1-14][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-15
    [22:18:57 230][HUB1-15][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-16
    [22:18:57 230][HUB1-16][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-17
    [22:18:57 230][HUB1-17][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-18
    [22:18:57 230][HUB1-18][Inf]--Update device path
    [22:18:57 230][Global][Inf]--Update HUB1-19
    [22:18:57 230][HUB1-19][Inf]--Update device path
    [22:18:57 231][Global][Inf]--Update HUB1-20
    [22:18:57 231][HUB1-20][Inf]--Update device path
    [22:18:57 231][Global][Inf]--Update HUB1-21
    [22:18:57 231][HUB1-21][Inf]--Update device path
    [22:18:57 231][Global][Inf]--Update HUB1-22
    [22:18:57 231][HUB1-22][Inf]--Update device path
    [22:18:57 231][Global][Inf]--Update HUB1-23
    [22:18:57 231][HUB1-23][Inf]--Update device path
    [22:18:57 231][Global][Inf]--Update HUB1-24
    [22:18:57 231][HUB1-24][Inf]--Update device path
    [22:18:57 248][HUB1-1][Inf]--Device is connected
    [22:18:57 248][HUB1-1][Inf]--Close device handle 0x00000b28
    [22:18:57 309][HUB1-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&16bdd27b&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000ab4
    [22:19:02 374][HUB1-1][Inf]--0-7-0-16
    [22:19:02 374][HUB1-1][Inf]--CheckFileRunState succeed
    [22:19:02 374][HUB1-1][Inf]-- low_power
    [22:19:02 379][HUB1-1][Inf]--Send command success
    [22:19:02 383][HUB1-1][Inf]--Read command status success
    [22:19:02 383][HUB1-1][Inf]-------------Download meson1.dtb-----------
    [22:19:02 384][HUB1-1][Inf]--0-7-0-16
    [22:19:02 384][HUB1-1][Inf]--Enc(0xadfc318c)
    [22:19:02 384][HUB1-1][Inf]-- download mem dtb normal 88064
    [22:19:02 384][HUB1-1][Inf]--Send download command success
    [22:19:02 398][HUB1-1][Inf]--Read command status success
    [22:19:02 411][HUB1-1][Inf]--Transfer complete
    [22:19:02 411][HUB1-1][Inf]--Send download get_status command succeed
    [22:19:02 414][HUB1-1][Inf]--get_status success
    [22:19:02 917][HUB1-1][Inf]-------------ERASE FLASH-----------
    [22:19:02 917][HUB1-1][Inf]--disk_initial 2
    [22:19:02 917][HUB1-1][Inf]--Send command success
    [22:19:07 134][HUB1-1][Inf]--Read command status success
    [22:19:07 134][HUB1-1][Inf]-------------Download _aml_dtb.PARTITION-----------
    [22:19:07 135][HUB1-1][Inf]--0-7-0-16
    [22:19:07 135][HUB1-1][Inf]--download store _aml_dtb normal 88064
    [22:19:07 135][HUB1-1][Inf]--Send download command success
    [22:19:07 150][HUB1-1][Inf]--Read command status success
    [22:19:07 349][HUB1-1][Inf]--Transfer complete
    [22:19:07 349][HUB1-1][Inf]--Send download get_status command succeed
    [22:19:07 353][HUB1-1][Inf]--get_status success
    [22:19:07 353][HUB1-1][Inf]--verify sha1sum 197e1097979afed6e44c3169d45c299c0c305827
    [22:19:07 353][HUB1-1][Inf]--Send verify cmd succeed
    [22:19:07 410][HUB1-1][Err]--failed:Verify Failed with sha1sum, origin sum "197e1097979afed6e44c3169d45c299c0c305827" != gen sum "cd1283a0f48e9fe5dac17150e4cf6169bce18057"
    [22:19:07 417][HUB1-1][Err]--[0x30405004]UBOOT/Partition _aml_dtb/Verify patition/Error result
    [22:19:07 417][HUB1-1][Inf]--Close device handle 0x00000ab4
