Mecool M8s Pro W struck on red light on power on
    Hi
    I recently bought Mecool M8s Pro W from gearbest. The box suddenly stopped working and the tv screan started blinking. When I restarted the box now its struck on red light on power on instead of blue and no display on TV .
    I tried reset by opening the box and shorting reset pins but no use. Kindly guide me how to recover it .
    I have same problem did you fix it
      Hi me too,
      ...but sometime is trying to boot and freeze at black MeCool logo, sometimes at blue design and sometime didn't start at all - red led only.
      After checking on internet it looks that the fault is a hardware issue -the GPU(which is SoC), for that reason the tiny red stripes on screen in my case and/or the eMMC ROM module.
      Attach a relevant pictures and the funny reply from Geekbuying...;-)Click image for larger version  Name:	To reset -Press menu...;-).JPG Views:	1 Size:	46.0 KB ID:	771759
        Video issue sounds like a cheap HDMI cable is being used! Red light sounds like either wrong flash or corrupt flash! You will need to jump the pins on the flash rom to get your unit to flash again!
