network selection disabled association rejection". Already tried removing the connection. Other wifi are working fine with same type of connection (WPA2 psk). Any idea on how to solve this? |
Hi, I didn't succeed on connecting to my home wifi from my mecool m8s pro L with stock firmware (20180803). I got the message "Tags: None
hi,
So, you can connect to other routers.
i would first check the router log.. checking if its not a router issue vs tvbox issue
*some tvboxes change Mac address... router thinks its a attack -reject the connection ( for example )
or
use WiFi advanced settings : manual add wifi
just some thoughts... happy Holliday's
or
I saw on one plus forum that there was a similar problem, solved with a fix...
I tried adding the connection manually, also setting static ip address...no way.
Am I the only one facing this problem?
There are currently 1738 users online. 0 members and 1738 guests.
