Enjoy High Speed Life with Tenda AC10 Wireless Router
    Tenda AC10 router is a high-performance router, which is designed for more than 200M optical fiber, offering dual-band Gigabit wireless with all new 802.11ac Wave 2.0 WiFi. The advanced MU-MIMO technology is adopted to make massive improvements. With dual-band WiFi, the 5GHz band works at up to 867Mbps, while the 2.4GHz frequency tops 300Mbps, the data transfer speed can be increased to 1167Mbps. Its powerful 1GHz CPU and 128MB DDR3 provide the best performance in both 2.4GHz and 5GHz. In addition, four high-gain antennas can bring you wider coverage and better performance. Perfect option for home, office and other places!
    Product Features:
    ● 1GHz CPU made with 28nm process, manifests excellent capacity on data processing and energy conservation.
    ● Dual-band 2.4GHz + 5GHz WiFi for faster wireless transfer speed, as high as 1167Mbps.
    ● Four external 5dBi high-gain antennas provides stronger network signal and wider WiFi coverage.
    ● Beamforming technology improves the capability of penetrating walls.
    ● Advanced MU-MIMO technology intelligently distribute data flow, improves network utilization rate, supports multi-device communication.
    ● Designed with full Gigabit WAN and LAN ports, removing the bottleneck of wired ports speed when working with faster bandwidth of optical fiber.
    ● Tenda WiFi APP allows to upgrade online, manage network and devices remotely and get a real-time understanding of router usage.
    ● Works well with optical fiber with bandwidth ranging from 50M, 100M, 200M to even 1000M.
    If you forget your PPPoE user name or password, or you cannot login to the web UI of the router for setup, AC10 can eliminate your concern by migrating your PPPoE user name and password from your original router. Such an outstanding router of only $33.99 on GearVita, what reason do you have to reject it? https://gearvita.com/tenda-ac10-wireless-router.html
    You may like:
    lenovo z5 pro 64gb in stock
    best xiaomi car charger double usb cc05zm
