MAGICSEE N5 Max TV box Amlogic S905x2 SoC 4gb/32gb 4gb/64gb
I couldn't find any review on this one its on flash sale. If someone could do a review on this I would be grateful. I am thinking of buying this instead of a95x plus because it has a card slot. A95x plus is perfect for me but its card slot problem is becoming a big issue for me. If anyone could clarify on that as to whether games can be installed to usb slots or not?Tags: None
Originally posted by romcrazy View PostI couldn't find any review on this one its on flash sale. If someone could do a review on this I would be grateful. I am thinking of buying this instead of a95x plus because it has a card slot. A95x plus is perfect for me but its card slot problem is becoming a big issue for me. If anyone could clarify on that as to whether games can be installed to usb slots or not?
Most other devices have zero updates and will be plagued by problems that will never be fixed.
Just keep it in mind when buying a new device.
I think the only S905x2 device with software support is the Beelink S905x2 since they already had 9 software updates.
MAGICSEE N5 Max TV Box Android 8.1 Amlogic S905X2 4GB DDR4 + 32GB / 64GB EMMC 2.4GHz + 5GHz WiFi BT4.1
Main Features
● Android 8.1 operation system
● Amlogic S905X2 CPU, Quad core, ARM Cortex-A53, 2.0GHz
● ARM Dvalin MP2 GPU
● 4GB DDR4 RAM + 32GB / 64GB EMMC ROM
● 2.4GHz + 5GHz dual band WiFi
● 1000Mbps Ethernet
● Support 4K ultra HD image display
GearbestLast edited by trebor; 25 February 2019, 21:36.
Yesterday got it
Code:https://4pda.ru/forum/index.php?s=&showtopic=942000&view=findpost&p=8292 3652
WiFi AP 6255.
Departure from China Canon:
- there is no metal plate (and gum) on the top cover above the radiator (processor));
- the radiator's glued, b!
For the initial setup, I connected the Logitech m185 mouse through the unifying receiver (removed it after connecting the BT mouse).
Ethernet in statics does not work, only in DHCP.
Wi-Fi turned off, not use.
BT ON: connected Oklick 595MB mouse and Logitech K375s MULTI-DEVICE clave.
ROOT is
exFAT is supported
restart: Settings-About-Restart
Shortly - i cant recommend it.
[ROM] AndroidTV 9.0 for N5MAX ver5 attachment Changelog - AndroidTV - Based On Official N5MAX X2 9.0 Firmware - Added support for init.d scripts - Updated busybox - GPU overclocking - TWRP 3.1.1 recovery - 14 WiFi channels - Ad blocking on hosts - Configs for game consoles and gamepads - Google screensavers withoutLast edited by SlimHouse; 02 November 2019, 13:38.
There are currently 1550 users online. 0 members and 1550 guests.
