[ROM] aml_7.1.2_s912_q9377-S912_mac-20180409_H96PROPLUS_LOGO_ubootfix_816Mhz
    aml.1.2_s912_q9377-S912_mac-20180409_H96PROPLUS_LOGO_ubootfix_816Mhz
    This is developed by: Shonk
    Works on Cz-cs32-v2.2 Green board (Non LP)
    • Rooted (SuperSu apk not installed)
    • ATV or standard launcher supported.
    • Remote: start and shudown works!
    • Google Play (Some apps incompatible..Device I.D. type?)
    • Antutu 7 score: 58998
    • Krypton 17.6 plays 4K streams fairly smooth
    • Web streaming works very good.
    • Youtube 1080p (works ok...)
    ??Mouse seems somewhat "jerky" compared to firmware 20180607-LP (v5 box)
    ?? Backdrop/Dream screensaver option not available.
    Overall a sweet relief from outdated firmware for this box
    ​​​​​​​@Shonk, Good work
    *** Not too sure the difference between this and the 4k option of:
    aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k4.img
    Hello and thanks for your work.
    I've got a CZ-S32-V6.1 which I use with CoreElec. But turn on is not working and I wander if flashing your rom can fix this issue, and also if your v5-v6 will work as mine is v6.1
    Thx
      Cz-cs32-v2.2
      Take a look at Shonk's other folders for an appropriate firmware.
      CoreElec
        v.5 and v.6 are from Shonk's other folder, that's why I'm asking him, because a already looked at other folders and did not see v6.1.
          Yes.
          Firmware v6 and v6.1 may be similar, or it may brick your China Box. Try to google the difference between v6 and 6.1, Flashing know firmware can be risky. Flashing unknown firmware is always extremely risky.
