I hope you can help me with my problem.
I've got two H96 Max+ (CPU: RK3328, RAM: 4GB, ROM: 32GB, OS: Android 8.1).
The device is already rooted.
Unfortunately both devices have the same serial number, so I want to change the serial number (can't use an app on both devices simultaneously because of the serial number)
I try to install Xposed (via APK) but I get following error:
gzip: short write
Error 1 occurred
I couldn't find a way to change the serial number without Xposed.
Thank you very much!
Best wishes
Kumar
