X96S Display Dongle/Stick A8.1 Amlogic S905Y2 Dual WiFi BT4.2
Good little Startup/Animation
Set up with Wizard Wifi and Google piece of cake,
Interesting and Different UI as will be seen.
Updated a couple apps and installed testers etc.
Has Root access, No SU, also no Upper or Lower Bars.
Remote is only OK, I find needs to be Inline with IR extension or NADA.
Using Logitech k400 ok, Enter/Q problem easy fix.
Found using Mouse on Logitech, the accuracy of clicking on Icons can be hit and miss to non existant thinks its an A8 thing.
Run's a little warm small space not Air Flow to be expected.
As Always,
Benchmarks are just to give an Idea of what going on in the Unit,
Let's have a look:
Boot Video:
Startup Wizard:
UI, Installed Apps:
All Up To Date:
More Can be found on Teardown, Test and discussion:
https://forum.freaktab.com/forum/tv-...ual-wifi-bt4-2
