Need help: How to root T-R42
    Hello folks,
    I received my new T-R42 TV Box. The stock firmware is not rooted and so I was searching the web for a rooting guide.
    I found a guide for the K-R42:
    Unfortunately the ADB-USB-driver for K-R42 does not work for the T-R42. My PC recognizes the device but I have no working driver for it.
    Does anyone have a working solution to root the T-R42?
    Steffen
    install moborobo and google tpsarky.
    you should figure out the rest
    Everything is possible if we work together!
    ApkFreak
      Hey lewy20041,
      Moborobo is installed and working...
      The T-R42 was found...
      But when I try to run the Batch-File for the rooting process I get the following error message:
      error:
      adb server is out of date. killing...
      ADB server dindn't ACK
      * failed to start daemon *
      Any idea?
      Steffen
        on pc go to system drivers and click actualize drivers.
        point to drivers directory (drivers are in my firmware package to).
        if that dont help we try something else.
        ApkFreak
          Hey,
          it was another problem:
          Before running the root batch tool, Momorobo has to be closed...
          Now my T-R42 is rooted
          Steffen
            Thanks for all the tips.
            My T-R42 is rooted.
            T-R42 v1.0 ; Ubox R89
              im glad i could help
              ApkFreak
                Originally posted by sgei View Post
                Hey,
                Steffen
                I have the same problem.
                Eric from Geekbuying says that we should press the recovery button when we connect to the pc.
                I did that and the pc see the drivers and installs them .But when I release the button pc don't see it again.
                What should I do? Please help...
                Thanks in advance...
