Beelink J45 Intel Apollo Lake Pentium J4205 Windows 10 Mini PC
    Beelink J45 Intel Apollo Lake Pentium J4205 8GB DDR4 256GB mSATA SSD Windows 10 Mini PC Dual Band WiFi Gigabit LAN Bluetooth USB3.0*4 HDMI*2 2.5 inch HDD Bay
    8GB+256GB / 8GB+128GB / 4GB+128GB For your reference.
    Pentium J4205 is a quad-core 64-bit x86 desktop microprocessor. It is manufactured on a 14 nm process. The chip operates at 1.5 GHz with burst frequency of 2.6 GHz and has a TDP of 10 W. This GPU incorporates Intel's HD Graphics 505 GPU operating at 250 MHz with a burst frequency of 800 MHz.
    Windows 10
    It is pre-installed with Windows 10 home so that our users are able to enjoy the advanced functions of Windows OS directly. Moreover, the built-in Cortana in Windows 10 can turn Beelink J45 into a work assistant as well as life-partner.
    2.4G/5G Dual Band WiFi
    With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
    Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second.
    BUY NOW!
