My box is 709N1 Build, Version 7.1.2, And serial number starting with LPN1
Main screen flashes every so many seconds, Then I get a message LightHome needs to restart, or LightHome not responding
Originally posted by mark dolan View PostThen i tried to install a firmware and it didn't help i still get the flicker and a pop up of the software LightHome having a software issue from android and have to click on it to address it
you installed the same Rom as before , correct ??? , strange ,
maybe Dust or Dirt on Box HDMI or Cable ???
good luck / gefattern
But the cable would make the LightHome Launcher crash and make a Notification on the screen so you have to address it. Also I don?t have the location weather on the home screen, just a circle spinning around and I?m connected by ethernet and the WiFi is turned on and the clock are set to the time zone
I did re flash the box with the firmware from BeeLink website I found. I used a micro sd card. But the pop up of the LightHome still pops up and ask to shut down or it pops up to run it. The flickering issue is that you have to put the HDMI screen output setting at 1080-60hz and the screen now has no flicker. The BeeLink box puts out too much resolution which was creating crash out of the television prosseser. So now I emailed BeeLink for a answer on the pop up issue and see what there fix is. When I find out I?ll post it
Hi guys I have the same problem with the lighthome crashing all the times. I sent a email to beelink, because they give the ROM that I installed, but no answer yet, and same problem with the location, I can't set the location, is that wheel turning around, maybe because of this the memory is occupied and makes the lighthome app crash...?? What do you think?
Originally posted by starsrider View PostHi guys I have the same problem with the lighthome crashing all the times. I sent a email to beelink, because they give the ROM that I installed, but no answer yet, and same problem with the location, I can't set the location, is that wheel turning around, maybe because of this the memory is occupied and makes the lighthome app crash...?? What do you think?
think this has to do with bugs in the Firmware , but why you not use one of the CustomRom
that exist for your Box , think this is better then the stupid Stockrom full with bugs , you can
find more Infos here on FT , use , example , the "search" , good luck / gefattern
There are currently 1523 users online. 2 members and 1521 guests.
