I have one Unuiga 4G router box that use a S905W SoC, but with the original firmware the 4G/LTE is supported, but the USB camera does not work. I tested another firmware as atvxperience and USB camera works fine but they does not have support for GSM module.
Can anyone suggest me, how can enable the GSM module on the atvxperience firmware or enable USB camera on the another firmware. Both of them have root access and I have the .img files.
Thanks for your help.
Best regards
diegofn
