MXQ-4K NOT BOOT
Originally posted by qamaruae View PostHi bro
that tv box was hang only android not coming other windows I do upgrade with laptop same file done or same not usb disconnects cable
after not boots
do you really know how to flash a Rockchip Box , like yours , do you have the
right Stockrom to restore ???
good luck / gefattern
Originally posted by qamaruae View Postsir I KNEW BUT I DONT HAVE FLSH FILE
so you first must find the right Rom , remember the right Wifichip Version , because this
Boxes are build so often with diffrent Specs , you need Rom with correct Wifidrivers , what
Wifichip is used ??? , good luck / gefattern
- About MXQ-4K NOT BOOT
Hi Gefattern
I am new to this please guide me on this ;
Android/rk322x_box/rk322x_box 7.1.2/NHG47K/NV3
Above info on recovery mode and i did factory reset but still on starting showing MXQ PRO and after that MBOX .
Looking forward your helpful firmware which i can reinstall or what to do ?
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Hi there
Thanks for your reply.
I did factory rest only . As i came to know only this step through YOUTUBE.
I didnt flash rom yet as i dont know which firmware needed from where.
I got this from Malaysia local shop . As i am not in Malaysia now therefore contacted through chat and they are not ready to give any firmware asking to bring the device to them and will fix it .
yes it is 6051p chip for wifi as i know if i am right .
Thanks Khurram
Hi there
I wait even more than hour but it didnt work that is why i searched on youtube .
going to shop is to travel to reach one country to another country .
Actually it was wronglt shut down while there was app working and directly swithced off mistakenly . after that i didnt boot only stuck on MBOX logo.
It means there no other way to solve it ?
BR
Originally posted by Khurram View PostHi there
Thanks for your information as i had mentioned before i am totally new to this things don't know how to flash if possible can you share me the direct link as i don't know even how to read what exactly is the model or tech information ?
BR
first you need the Stock or working Rom , did you find one ??? after that you can flash
with PC , here are a Guide :
http://ugoos.net/blog/rockchip-firmw...flashing-guide
maybe they can help , you must ask :
mxqproject.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf mxqproject.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
important we need a working Rom , good luck / gefattern
Hi
i checked in RK3229 forum and found V88 & MA8-4K Android TV 6.0.1 ROM (1GB/8GB SV6051) w/Live Channels
will this work with mine one firmware ? Mine is Android/rk322x_box/rk322x_box 7.1.2/NHG47K/NV3 ( MXQ PRO 4K RK3229 1G/8G SSV6051 V1.8 )
i will try your link to understand how it work .
BR Khurram
There are currently 2396 users online. 1 members and 2395 guests.
