Since everybody is doing stuff for amlogic, i though in giving H6 boxes some love
Many thks to gearbest for sending me the device to play
Many Thks to my beta testers trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
THE SDK USED TO BUILD THIS ROM... IT WAS VERY BUGGY, SO I DID THE BEST I COULD!
Changelog SCV2:
- Fixed Voice control, Long press home to "call" it once inside it you dont need to press the mic button again to do another search, just say "ok google" in a good english
lol
- Also you now can use the "ok google" of Nova launcher (see in nova launcher settings) only downside is when you enable it, it will leave the mic always listening so if you are using a remote with mic ( like minix A3 remote ) it drains you battery's fast!
- Added both status and navigation bar, to use it just pull from the top.. the bars auto hide after a few secs or just press in another part of the screen to hide it!
- Other minor tweaks/optimizations!
- Btw on 1? boot, playstore needs to do some little updates, so if it do not open right away that is normal... just give it a few min after you enable wifi!
Bugs SCV2:
- See SCV1 bug section...
- In setup wizard, sometimes in the wifi part it stay in "connecting..." just press "finish" after you put your wifi password!
- Of course there is more bugs as always...
Changelog SCV1:
- Simple rom
- Cleaned it...!
- Added Nova launcher
- Fixed Google logins, give it up to 5 secs for it to open when you press login... dont go crazy and start pressing like a ... well... you know...
- Optimized the max i could.
- Fixed adb connection.
- Added AndroidTV screensaver ( default 5 min, you can change the time in settings/display/sleep )
- Added google assistant.
- Added double press home button to bring app switch... use the left or right arrows of the remote to close the open apps...
- Long Press Menu button to open search.
- And a lot of others sh*ts...
- Enjoy it
Bugs SCV1:
- CEC do not work and will never will!
- Many more i bet........ but must i simple cant fix myself with out the source!
Download:
- DOWNLOAD HERE Eachlink H6 Mini SCV2 ROM
- MD5: 1F833621A44AF5648B73D4F0563DFC5D
Install instructions:
- Well... Just use PhoenixSuit select the IMG.
- Do not press Upgrade button...
- Press reset hole button ( near usb ports ) keep it pressed
- And Connect the USB cable to USB2 port and the flash should start
- The Flash app will ask you something, press yes the 2 times it does...
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
