I have a tv box h96 pro + of 3gb ram and 32gb of memory, model 9377, on the plate it puts ZH01-S912-TVBOX-V3.0, it has android 7.1.2, q201_9377_userdebug 7.1.2 NHG47L, I would like to be able to update it to the latest version and that can be customized only via OTA, can you help me? What firmware should I put and how? Thank you
help h96 pro+ update firmware
hello,
I have a tv box h96 pro + of 3gb ram and 32gb of memory, model 9377, on the plate it puts ZH01-S912-TVBOX-V3.0, it has android 7.1.2, q201_9377_userdebug 7.1.2 NHG47L, I would like to be able to update it to the latest version and that can be customized only via OTA, can you help me? What firmware should I put and how? Thank youTags: None
Do you know what version of firmware you have now.(You might have the latest Wisdom(?) firmware already.)
Here is forum link with same request... a bit dated:
I asked the H96+ Pro Plus TV box to do a supersu update. I confirmed the review. The TV box was turned off and turned on again. Make your life stuck in the colorful
Wisdom folder(2017)
Taken from 4PDA.ru
Use any info at your own risk...
"ZH01-S912-TVBOX-V3.0 board with 8 chips. I have the same. Many firmware without an LP index are suitable. I myself put the sdn I still have the last aml_7.1_s912_q9377-S912_mac-20180409 (there is no need to patch the framework in it, I normally use third-party launchers). Firmware can be taken here . Installation Instructions here "
***If you get 20180409 firmware...I find that it plays Krypton 4K files fairly nice.***
Not sure..- Downloads work.. https://mega.nz/#F!8qhRRaYJ!2ZA3VLjvLT6wg0IwsTF27g
- License files would need to be placed into USB Tool folder.
- If you manage to download firmware..are you loading it first, before connecting the China Box?
- De-select "Reset after success"
There are currently 1838 users online. 1 members and 1837 guests.
